Creating an XML file for custom reports
To create an XML file for custom reports:
- Start and end the file with a <METADATA> and </METADATA> tag.
- For each custom report you want to load, create one REPORT tag. This tag has the following syntax:
<REPORT
[UUID="id"]
ASPFILENAME="name"
ASPTEXT="code"
QUERYFILENAME="name"
QUERYTEXT="text"
[SETUPFILENAME="name"]
[SETUPFILETEXT="name"]
[TITLE="name"]
[DESCRIPTION="text"]
[REPORTTYPE="ADMIN|NORMAL"]
[DATASOURCENAME="text"]
[DATASOURCEUSER="text"]
[DATASOURCEPASSWORD="text"]
[LANGUAGE="name"]/> - Assign the following values to the REPORT tag attributes:
Attribute
Value
UUID
Leave blank. A blank UUID indicates that the definition is for a custom report.
ASPFILENAME or
ASPTEXTName of the ASP file defining the report, or the actual ASP text. One of these is required.
QUERYFILENAME or
QUERYTEXTName of an SQL file defining the patient data retrieval needed for the report, or the actual SQL statements. Optional. These attributes are for documentation only.
SETUPFILENAME or
SETUPFILETEXTName of an SQL file defining report-specific tables, views, indexes, and stored procedures that are necessary to create the report, or the actual SQL statements. Optional. If specified, use one or the other of these attributes.
TITLE
Title of the report. This appears as a selectable link on the Custom tab and in the title bar of the report when it is generated online.
DESCRIPTION
Description of the report, for documentation only.
REPORTTYPE
Blank or NORMAL.
DATASOURCENAME,
DATASOURCEUSER,
DATASOURCEPASSWORDName, user name, and password of the ODBC data source used to access report data, if you are using a database other than the InForm application database—for example, a CDD.
LANGUAGE
Language used to display the caption. Optional. English is the default.
