Loading a custom report into InForm application
When you have created a custom report ASP file, you must:
- Define the report as an InForm application object by referencing it with a REPORT MedML tag in an XML file.
- Load the report definition into the database by processing the XML file with the MedML Installer tool.
This section describes how to use the REPORT MedML tag. For information on how to use the MedML Installer tool, see InForm Utilities Guide.
