Execution plan objects and methods
When you create an execution plan script, you can use the objects and methods described in this section.
Execution plans have access to several objects and their methods. You use these objects and methods to retrieve entered values and to hold values passed from the Patient or Result rule objects. For information on the execution plan objects and methods that are available with the InForm application, see the MedML online Help.
