Dynamic forms
Dynamic forms appear conditionally in a visit based on the result of a calculation defined on another form. For example, if you want to collect additional data from a female patient who is pregnant, you can define a dynamic form that appears in the trial only if the response to a question determining whether the patient is pregnant is yes.
