Date display format
The InForm application enables you to customize the form in which dates are displayed in the user interface. The following date formats are available:
- Month/Day/Year
- Day/Month/Year
- Year/Month/Day
You can specify the date format at the trial, site, or user level. The date format specified for a site overrides the format specified for the trial, and the date format specified for a user overrides the formats specified for the trial and the site.
If a user is assigned to more than one site, the date format defaults to the assigned trial date format.
The following table shows where to specify the date format for the trial, site, and user:
Level |
Where to specify formatting |
Trial |
Specify system configuration option on the System Configuration screen in the InForm application. |
Site |
Update the Date Format item on the Site screen by using the InForm application or the InForm Architect application. |
User |
Update the Date Format item on the User screen by using the InForm application or the InForm Architect application. |
