Creating a form definition
Select File > New > Form. A new Form window appears in the application workspace. The upper pane shows a hierarchical representation of the form and its child components. When you create a new form, a default Section icon is included.
The lower pane shows a preview of the form as it will appear in the InForm application.
The Properties window shows the properties that describe a form definition.
The Trial Objects window is updated to show the addition of the new form object.
