Using the Build RefName tool
When you create a rule script or when you define rule contexts and dependencies, you need to specify the RefName paths of each item the rule references. The Build RefName tool enables you to build a RefName path by choosing its components from a series of lists. Additionally, you can use the Build RefName tool to modify context and dependency RefNames and to specify a RefName path as the value of a default or context-specific string type argument.
Note: To ensure that the Build RefName tool appears correctly, do not change the appearance of your Microsoft Windows desktop to use a nonstandard font. Keep the desktop appearance scheme set to “Windows Standard.”
