General instructions for using the Build RefName tool
- Display the Build RefName dialog box.
Note that the InForm Architect application partially fills in the Path field if it can obtain information from the location from which you display the dialog box. The label for the list of RefNames and the RefNames in the list change according to the context. For example, after you select a visit RefName, the label and list prompt you to select an itemset or item name.
- For each component of the RefName path, select the component from the list in the dialog box.
- Click Next, or, to backtrack to a previous component, click Back.
The InForm Architect application builds the path from your selections and displays it in the Path field at the top of the dialog box.
- When the RefName path is complete, click Done.
The InForm Architect application inserts the path into the component definition you are creating.
