Displaying the Build RefName dialog box
How you invoke the Build RefName dialog box depends on what you are doing in the InForm Architect application when you need to build a RefName path, as described in the following table:
To display the Build RefName dialog while... |
Do this... |
Creating or editing a script |
1. In the Script tab of the Rule window, place the cursor where you want to insert a RefName. 2. Right-click in the Rule editor window. 3. Choose Build RefName from the pop-up menu. |
Updating the properties of a context |
In the Rule window, double-click the Context RefName of the context you want to update. |
Changing the RefName path of a dependency to associate the dependency with a different item in the same form and section Note: You cannot change the RefName path of the key dependency (the dependency created automatically when you add a context). |
In the Rule window, double-click the Dependency Path of the dependency you want to update. |
Defining an argument |
1. In the Rule window, double-click the argument for which you want to specify a RefName path. The RefName and Arguments dialog box appears. 2. Select the Value cell for the argument for which you want to specify a RefName path, and click the Build RefName button. |
