Creating a new item
- Open the form in which you want to include the item: double-click its icon in the Protocol Editor window or Trial Objects window.
- Select the section in which you want to create the item.
- Drag the item icon
in the Object Palette toolbar into the open Form definition window. To order the item first in the section, drop the icon onto the section icon. To create a subsequent item, drop the icon onto the item that you want the new item to follow.
