Specifying separate unique keys
Specifying separate unique keys for a repeating form or an itemset involves the same process. The illustrations that follow use a repeating form as an example.
To specify unique keys:
- Identify the key items for the form or itemset, as described in Enhancing navigation in repeating forms and Specifying key items for an itemset.
- In the Form editor window, right-click the form or itemset icon and select Make Unique from the popup menu.
- In the Make Unique dialog box, select the key items that you want to serve as unique keys when users add new form instances or new itemset rows.
- Click OK.
