Annotating forms
The InForm Architect application enables you to annotate the forms you create with design information about the controls, elements, dates and external mappings. This allows you to print out design copies of the forms for design review and approval.
Once you have the form and all its controls and properties created, you can choose the types of design information with which you want to annotate the form. The following options are available for producing annotated forms:
- Annotated View
- Annotated External Mappings Display
- Annotated Data Mappings Tables Display
The Settings menu bar icons that enable you to use these features are:
