Example of conversion rule for Centimeter unit
This example defines a unit called Centimeters. In this example, the Unit specified as the basis for conversion is Inches. Therefore, the conversion rule referenced in the Conversion to Base Rule property reflects the factor used to convert to inches from centimeters.
Property |
Value |
RefName |
CENTIMETERS |
Symbol |
CM |
Classification |
Length |
Base RefName |
Inches |
Conversion To Base Rule |
CmToInches Rule script text: Data.Result=Data.Basevalue*.3937 |
