Example of conversion rule for Inches unit
The properties in this example define a unit called Inches. In this example, inches are both the unit being defined and the unit specified as the basis for conversion, so the conversion rule specified in the Conversion to Base Rule property simply multiplies the entered value by 1:
Property |
Value |
RefName |
INCHES |
Symbol |
IN |
Classification |
Length |
Base RefName |
Inches |
Conversion To Base Rule |
UnitIsBase Rule script text: Data.Result=Data.BaseValue*1 |
