Selecting metadata for display
To select which metadata you want to appear on the form when it is in Annotated View and/or Annotated External Mappings Display, select View, Settings/Annotated CRF Settings. When you select the Annotated CRF Settings command, the following dialog box appears:
You can choose to display any of the following types of information about the form:
- No Annotated Information—When you choose this option, the Form window shows only the blank controls with no metadata.
- Selected Annotated Information—When you choose this option, the Form window shows the annotations you select.
- Time and Events Schedule Only—When you choose this option, a representation of the Time and Events Schedule appears in the Trial Design workspace when you select File, Annotated Trial Design. In the Annotated CRF Settings dialog box, all Selected Annotated Information check boxes are disabled. However, the Form window displays all of the selected annotations.
- All Annotated Information—When you choose this option, the Form window and the Annotated Trial Design window display every available annotation.
You can also choose whether or not to display a cover page and what it should include, and in what order to display the forms (alphabetically by title or as ordered in the Time & Events schedule). If included, the cover page appears in the Trial Design workspace when you select File > Annotated Trial Design.
