Data mapping tables
Data mapping tables show the following information for all mapped controls in CDD and Clintrial software mapping definitions:
- CDD—Data mapping name, table name, key type, column names, data types, possible values, and design notes.
- Clintrial—Data mapping name, panel name and properties, item names and properties of each item.
These tables appear when you select the Toggle Annotated Data Mappings Tables Display button or when you select the Data Mappings Companion Tables check box in the Annotated CRF Settings dialog box. The following figures illustrate a CDD mapping table and a Clintrial software mapping table:
