Designing CDD mappings
When designing CDD mappings, consider how you want to be able to retrieve the data from the CDD. Do you want to map multiple data points to the same CDD table column? Do you want to repeat a particular data point in each row of the table? Do you want to combine data from different visits, forms, or sections in the same CDD table?
