Mapping a form control
If you want to create new or additional mappings to an existing column definition, you must create a control mapping definition. This definition consists of the RefName path of the control, which is displayed but cannot be edited in the Properties window.
To create a control mapping, you can do either of the following:
- In the Data Mappings window, use the Add Control pop-up menu command for the column in which you want to create the control path.
- In the Form window, you can either use the Add Data Mapping pop-up menu command for the control you want to map, or you can drag the control from the Form window onto the Data Mappings editor window.
When you create a control mapping, the InForm Architect application generates control paths that use the Generic_Form visit type.
