Ordering columns in a table
When you add column definitions to a CDD mapping table, the InForm Architect application adds each new column to the end of the list. To rearrange the order of a column, drag and drop it on the name of the column you want it to follow. To insert it first in the list, drop it on the table name.
The InForm Architect application rearranges the MedML definition, and when you save and then use the MedML Installer to load the CDD mapping definition, the order you create is loaded into the InForm database and the CDD. Additionally, the CDD companion tables in the annotated CRF show the new order.
