Specifying properties for a control path
Along with its RefName path specification, a control path has an editable Data Label property, which is described in the following table:
Property |
Description |
Path |
RefName path of the mapped control. Read only. REQUIRED.. |
Data Label |
User-defined string to use for searching on data in the column. Maximum length is 30 characters. This label is included in the CDD mapping control path definition in the InForm database. For CDD mappings, it also appears in target CDD mapping tables that have any of the following key types: Patient to Control, Pivot Patient, Pivot Visit, Pivot Form, and Pivot Section. OPTIONAL. |
Design Note |
Free-form text, with a maximum of 255 characters, containing any information you want to capture about the design of the component. This information is for documentation only. OPTIONAL. Design Note text is not transferred to the target tables. |
