Defining CDD mapping table column properties
After creating a CDD mapping definition table column definition, specify its properties:
- Select the table column name in the Data Mappings editor window.
- Edit the CDD table column property values in the Properties window.
The following table describes the properties of a CDD mapping table column definition.
Property |
Description |
Name |
RefName of the component. REQUIRED. For rules about the use of RefNames, see RefNames |
Type |
Specifies the column type in the target table. Note that when you create a control mapping, the InForm Architect application attempts to specify an appropriate column type based on the data type of the control. If the control type is not known, the default Type is Text.
Length |
Maximum length of a column, in the range 1 - 255. This property is visible only when the column type is STRING. REQUIRED. if the column type is STRING. |
Design Note |
Free-form text, with a maximum of 255 characters, containing any information you want to capture about the design of the component. This information is for documentation only. OPTIONAL. Design Note text is not transferred to the target tables. |
