Using the Form window to create a column definition and control mapping
You can create a column and control mapping definition from the Form window. However, before you create a definition, the table in which you want to create the column definition must exist in the CDD mapping.
To create a definition from the Form window:
- Open the Form window containing the control you want to map, and expand the tree so that the control is visible.
- Right-click the control, and choose Add Data Mapping from the pop-up menu.
The Create New Data Mapping dialog box appears.
- Expand the tree so that the table in which you want to create the column definition is visible.
- Select the table.
The Add Column button becomes available.
- Click Add Column.
The InForm Architect application generates a definition for the column mapping and the control path.
You can also quickly generate a definition by dragging the control from the Form window onto the Data Mappings window.
Note: The InForm Architect application only allows you to drag and drop controls for which you can legitimately create mappings. You cannot drag and drop a simple control or a group control.
To drag a control from the Form window to the Data Mappings window:
- Open the Form window containing the control you want to map and expand the tree so that the control is visible.
- Open the Data Mappings window and expand the definition so that the table in which you want to create the column definition is visible.
- Drag the control from the Form window and drop it onto the table in the Data Mappings window.
