Mapping associations to a CDD
When a trial includes repeating forms that are linked in an association, you create mapping definitions for the association separately from other trial objects. An association is a pair of repeating forms that are linked to allow the online display of cross-references between forms and the enhanced navigation between instances of the forms. For more information about associations and for instructions for defining an association, see Associations.
When you auto-generate a CDD mapping, the InForm Architect application creates the association mappings along with the mappings of other trial objects. When you generate a CDD manually, you create an association mapping as described in Creating an association mapping manually.
