Data mapping components
When you generate a set of data mapping components, either by registering a Clintrial protocol in a CIS library or by creating the mappings with the InForm Architect application, the following mapping components are created:
- CONTEXT panel mappings
- Data panel mappings
- Item mappings
- Control paths
