CONTEXT panel mappings
Each Clintrial protocol has one CONTEXT panel. The items in the CONTEXT panel are attached as columns in a panel’s clinical data tables when the panel is installed. When the InForm Architect application generates a Clintrial mapping, either through autogeneration or when you create a manual mapping definition, it supplies a CONTEXT panel whose items correspond to Clintrial CONTEXT items.
In Clintrial software, you assign CONTEXT item names when you create the context panel for a protocol. For example, the Medika Clinical sample trial has the following CONTEXT panel item names.
CONTEXT panel item name |
CONTEXT item |
SUBJECT |
Subject Item |
VISNO |
Block Key Item |
PAGENO |
Page Key Item |
VISRPT |
Block Repeat Key Item |
PAGERPT |
Page Repeat Key Item |
The CONTEXT panel items created from the mappings generated with the InForm Architect application have the following default names, established by the RefNames of the CONTEXT panel mapping definitions.
Corresponding InForm trial object |
CONTEXT item |
PATNUM |
Patient number |
Subject Item |
VISITID |
Visit |
Block Key Item |
FORMID |
Form |
Page Key Item |
VISITINDEX |
Repeating visit index |
FORMINDEX |
Repeating form index |
Note the following implications of assigning CONTEXT item names:
- When you design a trial with the InForm Architect application and synchronize to Clintrial software, the corresponding Clintrial protocol and panels are created automatically using the CONTEXT panel item RefNames assigned in the mappings generated by the InForm Architect application.
- When you design a trial in Clintrial software and import a Clintrial protocol to a CIS library, the autogenerated CONTEXT panel mappings preserve the CONTEXT item names assigned in the Design module.
- If you are running a hybrid trial or an EDC trial that includes components designed in both InForm Architect application and the Clintrial Design module, and the mappings do not match, data entered with InForm application and data entered with the Clintrial. Enter module is stored in data tables with different column heading names. You must ensure that data selection for your reports takes this into account.
If you want the mappings generated by InForm Architect application and CIS to match, do one of the following:
- Ensure that the CONTEXT item names assigned when you create a protocol with the Clintrial Design module match the CONTEXT item names generated by InForm Architect application, as shown above.
- In the mapping definitions generated by the InForm Architect application, change the RefNames of context panel items as needed before saving the trial MedML.
