Working with additional CONTEXT panel items
The InForm Architect application generates mappings for the CONTEXT panel items.
The Clintrial Design module enables designers to define more CONTEXT panel items in addition to the ones handled by the InForm Architect application. For example, you could create a CONTEXT item called PROTOCOL, which would contain the protocol name in each record. Since the InForm Architect application does not automatically generate mappings and pass default values for additional CONTEXT panel items, users of the Enter module must manually enter the protocol name for each patient record.
If you desire additional CONTEXT items to be populated for EDC patients, you can create a derivation on the CONTEXT panel in Clintrial software to populate additional context panel items for EDC records.
