PANEL mappings
In an automatically generated Clintrial mapping definition, each PANEL mapping definition corresponds to a panel in a Clintrial trial and to a form in an InForm trial. The RefName specified in a PANEL mapping definition is the panel name in the Clintrial protocol to which it is mapped.
In the InForm Architect application, you can also create PANEL mapping definitions that do not correspond directly to an InForm form. For example, you can create a mapping definition that generates a type 0 panel for non-patient data that will be populated from within the Clintrial software. For more information, see Creating a type 0 panel.
