ITEM mappings
Each ITEM definition in a set of automatically generated Clintrial mappings represents the correspondence between a panel item in the Clintrial software and a form item in the InForm application.
When you design a trial in the Clintrial software and import a Clintrial protocol to a CIS library, CIS creates an ITEM mapping definition for each panel item.
When you design a trial with the InForm Architect application and generate mappings, the InForm Architect application generates one ITEM mapping definition for each item in each form. Compound controls (radio groups and check box controls) in the InForm Architect application are mapped to a single column; you can manually add items defining mappings to columns that hold the data for each individual control.
