Autogenerated mappings and protocol imports
When you import a Clintrial protocol to a CIS library, CIS generates data mapping definitions for the following protocol components:
- The CONTEXT panel
- The following CONTEXT panel items:
- PATNUM
- VISITID
- FORMID
- VISITINDEX
- FORMINDEX
- Each data panel
- Each panel item
CIS stores the data mapping definitions along with translated metadata definitions in the library protocol. When you import a protocol to the InForm Architect application, you specify whether to include the mapping definitions in the import. Once you have imported the mapping definitions to the InForm Architect application, you can customize them as needed, save them, and install them in an InForm trial.
