Autogenerated mappings with the InForm Architect application
When you autogenerate mappings with the InForm Architect application, you specify:
- How you want column names to be generated.
- How you want date and time data to be mapped. Consider whether you want dates and times to be accessible:
- As a single column or as separate columns for each part of the date or time.
- As strings, integers, or complete DATE or DATETIME data types.
The automatic mappings feature maps all items, in all sections of an InForm form, to a single Clintrial panel. This feature automatically generates the panels, panel items and mapping details for a trial in the Data Mappings window of the InForm Architect application.
If multiple instances of a form are used within the InForm Architect application, you can see only one Clintrial panel for all instances of the form. The database tables (panels) in the Clintrial software include the appropriate references.
