Mapping definition object properties
The following table describes the properties of a Clintrial mapping definition.
Property |
Description |
RefName |
RefName of the component. REQUIRED. |
Type |
CLINFORM. READ-ONLY. |
Active |
Active or Inactive, indicating whether the Clintrial mapping definition is accessible with the InForm Architect application. The default is Active. To disable a Clintrial mapping definition, set the value to Inactive and install the definition by saving it with the Install MedML When Saving option enabled or by using the MedML Installer utility. The Clintrial definition becomes inaccessible with the InForm Architect application. OPTIONAL. |
Auto Generated |
True or False, indicating whether the Clintrial mapping is in Auto-Generate mode. In this mode, when you add a new control to a form in the Form window, the InForm Architect application automatically generates a Clintrial mapping for it at the end of the list of column definitions in the target table. REQUIRED.. |
Design Note |
Free-form text, with a maximum of 255 characters, containing any information you want to capture about the design of the component. This information is for documentation only. OPTIONAL. |
