Creating a panel mapping definition
A Clintrial panel represents a set of related items. When you autogenerate a Clintrial mapping, each form in an InForm trial corresponds to one Clintrial panel.
To create a panel mapping definition manually:
- Open the Data Mappings window for the mapping in which you want to create a new panel mapping.
- Right-click the Data Mappings node and select New Panel from the right-click menu.
The InForm Architect application generates a panel definition.
- Edit the Clintrial panel property values in the Properties window. For more information, see Panel mapping properties.
