Panel mapping properties
The following table describes the properties of a Clintrial software panel mapping definition.
Property |
Description |
Panel Name |
Name of the panel. REQUIRED.. |
Description |
Description of the panel. REQUIRED.. |
Type |
A specification of how the database tables associated with the panel are structured:
REQUIRED.. |
Subset Item |
Name of the item specified as the subset key for subset page sections based on the panel. OPTIONAL. A subset page section can occur multiple times on a trial page in the following types of panels, with each value of the subset key item representing distinct rows (subsets) of data:
For more information, see Implementing Clintrial subsets. |
Protected |
True or False, indicating whether access rights to the panel are limited in the Clintrial software. False is the default. OPTIONAL. |
Verifiable |
True or False, indicating whether double-entry of data in panel items is required for verification. False is the default. OPTIONAL. |
Detail |
True or False (default), indicating whether the panel definition participates in a detail page section in a master-detail relationship. A master-detail relationship is a relationship between two page sections on a study page, in which each record in one page section (the master page section) can have one or more associated records in the other section (the detail page section). During data entry the displayed records in the detail page section are associated with the selected record in the master page section. REQUIRED.. |
Detail CTItem |
Name of the item identified as the detail key item, if the panel definition is part of a detail page section. OPTIONAL. |
Master Panel |
Panel name of the master panel with which this panel definition participates in a master-detail relationship. This property applies only if the Is Detail property is True. OPTIONAL. |
Master Item |
Name of the item on the associated master panel that corresponds to the detail key item specified in the Detail CTItem property. This property applies only if the Is Detail property is True. OPTIONAL. |
SAS Name |
Name of the panel when data is sent to SAS through the Clintrial SAS interface. OPTIONAL; if entered, the name must be 8 characters or fewer and conform to SAS naming requirements. Note: Panel SAS names must be unique within a protocol. You must make sure of their uniqueness, as the CIS software does not enforce this restriction. |
Lock Status |
Indicates whether the protocol in which the panel is included is locked:
