Creating a panel item mapping definition
Creating a Clintrial panel item mapping definition with the InForm Architect application has two parts:
- Defining an item in a Clintrial panel.
- Identifying the form controls that map to the item.
You can do these activities as separate steps, or you can create both the item and the control mapping in a single step.
