Creating only an item definition
To create an item definition that does not include a control mapping:
- In the Data Mappings window, right-click the name of the panel in which you want to create a new item.
- From the right-click menu, select New Item Definition.
InForm Architect application adds a new item line to the panel node in the Data Mappings window.
- Edit the item mapping properties in the Properties window. For more information, see Item mapping properties.
