Creating an item definition and mapping a control
To create an item definition and control mapping in a single step, you can do either of the following:
- In the Data Mappings window, use the New Item right-click menu command for the table in which you want to create the column and control definition. For more information, see Using the Data Mapping window to create an item definition and control mapping.
- In the Form window, use the Add Data Mapping right-click menu command for the control you want to map, or you can drag the control from the Form window onto the Data Mappings window. For more information, see Using the Form window to create an item definition and control mapping.
