Item mapping properties
The following table defines the properties of an item mapping definition:
Property |
Definition |
RefName |
RefName of the component. REQUIRED. For rules about the use of RefNames, see RefNames |
Type |
Data type for the value of the item:
Length |
Number of characters that can be entered in this item. The default is 38. OPTIONAL. This property is visible when the Type is TEXT, FIXED, or FLOAT. |
Precision |
Number of characters that can be added after the decimal place in an item with a type of FLOAT. This value can be a number between 1 and 15. The default is 10. If you enter 0, the precision defaults back to 10. If you enter a number greater than 15 is chosen, the precision defaults back to 15. OPTIONAL. This property is visible when the Type is FLOAT. |
DB Format |
Format in which Clintrial software stores values for the item in the Oracle database, for example:
Date Part |
Part of a date time control to be mapped to a Clintrial software item. Use this property if you are mapping parts of a date time control to separate Clintrial software items. Values are:
Derived |
True or False, indicating whether the value of the item is determined from a derivation associated with the panel. False is the default. OPTIONAL. |
Required |
True or False, indicating whether the item is required. False is the default. OPTIONAL. |
SAS Name |
Name of the item when data is sent to SAS through the Clintrial SAS interface. OPTIONAL; if entered, the name must be eight characters or fewer and conform to SAS naming requirements. |
Repeat |
True or False, indicating whether an item is one for which multiple values can be entered within a page section. False is the default. OPTIONAL. |
Code List |
Name of a Clintrial codelist associated with the item. A codelist encodes entered values. Only codes or values in the codelist can be entered as values of the item. OPTIONAL; Code List and Check List are mutually exclusive. |
Check List |
Name of a Clintrial checklist associated with the item. A checklist is a type of codelist used to view suggested entries for a field. OPTIONAL; Code List and Check List are mutually exclusive. |
Range Lower Bound |
Minimum value that can be entered for the value of the item. OPTIONAL. This property is visible if the Type is FIXED or FLOAT. |
Range Upper Bound |
Maximum value that can be entered for the value of the item. OPTIONAL. This property is visible if the Type is FIXED or FLOAT. |
Key Order |
The order in which the item appears in the concatenation of key items, if the item is part of the panel's key. 0 (not a key item) is the default. OPTIONAL. |
Copy with Panel |
Name of a Clintrial codelist associated with the item. A codelist encodes entered values. Only codes or values in the codelist can be entered as values of the item. OPTIONAL. |
Lock Status |
Indicates whether the protocol in which the item is included is locked:
OPTIONAL. |
Design Note |
Free-form text, with a maximum of 255 characters, containing any information you want to capture about the design of the component. This information is for documentation only. OPTIONAL. Design Note text is not transferred to the target tables. |
