Creating a control path mapping definition
If you want to create new or additional mappings to an existing item definition, you must create a control mapping definition. This definition consists of the RefName path of the control, which is displayed but cannot be edited in the Properties window.
To create a control mapping, you can do either of the following:
- In the Data Mappings window, select the Add Control right-click menu command for the item in which you want to create the control path. For more information, see Using the Data Mappings editor window to create a control mapping.
- In the Form window, select the Add Data Mapping right-click menu command for the control you want to map, or you can drag the control from the Form window onto the Data Mappings window. For more information, see Using the Form window to create a control mapping.
When you create a control mapping, The InForm Architect application generates control paths that use the Generic_Form visit type.
