Changing panel properties
To update Clintrial panel properties:
- In the Trial Objects tree of the InForm Architect application, double-click the node for the mapping definition containing the panel you want to modify.
The Data Mappings window appears.
- Expand the data mappings tree to expose the panel.
- Select the panel.
The Properties window for the panel appears.
- In the Properties window, change the panel properties as desired, and click Enter.
The InForm Architect application updates the panel mapping properties.
- Save the mapping definition.
