Panel properties you can change
The following table lists the Clintrial panel properties you can change through CIS synchronization and the InForm Architect panel mapping definition properties to which they correspond.
Clintrial panel property |
InForm Architect panel mapping property |
SAS Name |
SAS Name |
Verify |
Verifiable |
Protected |
Protected |
Description |
Description |
