Making panel property changes
After a panel is installed in the Clintrial software, you can change the following properties by marking the panel for revision in the Design module:
- SAS Name
- Validation Priority
- Verify
- Protected
- Description
Some of these properties are included in an InForm Architect panel mapping definition. By updating panel mapping properties with the InForm Architect application, you can make changes to a panel definition. After you update a trial with the panel mapping properties changes, CIS synchronizes the changes to the Clintrial software.
