Subset mapping properties
InForm Architect mapping definitions include properties that enable you to specify that CIS should treat certain data items as subset data when synchronizing to the Clintrial software. These properties are:
- Subset Item—This property of a panel mapping definition specifies the name of the Clintrial panel item designated as the subset key item. The value of this item determines with which record a group of subset data is stored.
If this property is specified, the item mappings for the panel should include an item with the name specified as the subset item name. No controls from an InForm form should be mapped to that item.
- Subset Value—This property of a control path mapping definition specifies the value of the subset key item with which the data in the control is stored. When CIS synchronization stores the data in the control in the Clintrial database, the data goes into a record for which the subset key item has the specified Subset Value.
If a panel has a subset item, every control path mapping to that panel must specify the subset value.
