Autocode mapping workflow
To use the InForm Architect application autocode mapping feature in autocoding activities:
- Design target calculated controls in forms where you want autocoded values to be inserted. For information about creating calculated controls, see Creating a new calculated control.
Note: The Calculated property of the item in which you create a calculated control must be set to True.
- Map these controls to source controls containing values to be autocoded.
- In a production trial, export data using the Autocode option of InForm Data Export. For information about using InForm Data Export, see InForm Utilities Guide.
- Use an external autocoding utility to assign codes to the exported data.
- Use the Autocode Import file option of InForm Data Import to import the code values to the calculated controls you created in the trial database. For information about using InForm Data Import, see InForm Utilities Guide.
