Differences between Autocode mapping and Central Coding mapping
The Autocode mapping and Central Coding mapping features of the InForm Architect application both help you to design your trial so that you can export certain data as verbatim text, process it with an external coding application, and reimport it to the trial in coded form. The following table summarizes the differences between these mapping features:
Autocode mapping |
Central Coding mapping |
Coding application |
Any external coding application that can be customized to accept a data file from InForm Data Export. |
Central Coding |
Mechanism for exporting and importing data |
Exported and imported by InForm Adapter. |
Number of code targets per verbatim |
One |
As many as the specified dictionary allows. |
Number of context items per verbatim |
None |
As many as the specified dictionary allows |
Type of control for storing coded data |
Must be a calculated control. |
Can be a text control or calculated control. Text controls provide an audit trail; defining them as read-only is recommended. |
Dictionary support |
None |
MedDRA and WHODD |
