Creating a coding mapping object
The coding mapping object for a trial holds the mapping definitions for all coded items. Before creating a coding mapping object, use MedML Installer to install the XML defining the dictionary in the InForm software database.
To create a coding mapping object:
- In the Trial Objects window, right-click Data Mappings and select Create Coding.
The Data Mappings window opens in the trial workspace.
- Edit the Central Coding mapping property values in the Properties window. For more information, see Coding mapping object properties.
