Coding mapping object properties
The following table describes the properties of a coding mapping object:
Property |
Description |
RefName |
RefName of the component. REQUIRED. For rules about the use of RefNames, see RefNames |
Type |
CODINGMAP. READ ONLY. |
Active |
Active or Inactive, indicating whether the coding mapping definition is accessible with the InForm Architect application. The default is Active. To disable a coding mapping definition, set the value to Inactive and install the definition by saving it with the Install MedML When Saving option enabled or by using the MedML Installer utility. The coding definition becomes inaccessible with the InForm Architect application. OPTIONAL. |
Design Note |
Free-form text, with a maximum of 255 characters, containing any information you want to capture about the design of the component. This information is for documentation only. OPTIONAL. |
