Disabling a coding mapping object
To disable a coding mapping definition:
- In the Trial Objects window, double-click the name of the coding mapping object.
The Data Mappings window opens with the mapping object name selected.
- In the Properties window, set the value of the Active property to Inactive.
- Install the definition by saving it with the Install MedML When Saving option enabled or by using the MedML Installer utility.
The coding mapping definition becomes inaccessible with the InForm Architect application.
