Identifying controls to be coded (verbatims)
Verbatim control mappings identify the controls on an InForm application form that hold data to be coded. You can add, change, or remove a verbatim control mapping.
To add a verbatim control mapping, use either of the following methods:
- In the Data Mappings window, specify a RefName path. For more information, see Specifying a RefName path to add a verbatim control mapping.
- Drag the control from the Form window to the Data Mappings window. For more information, see Dragging a control to add a verbatim control mapping.
