Specifying a RefName path to add a verbatim control mapping
To add a verbatim control mapping by specifying a RefName path:
- In the Trial Objects window, double-click the name of the coding mapping object.
The Data Mappings window opens with the mapping object name selected.
- Right-click the node for the visit in which the verbatim occurs, and select Add Verbatim from the right-click menu.
The Build RefName dialog box appears.
- Use the Build RefName dialog box to specify the RefName path. For more information, see General instructions for using the Build RefName tool.
The InForm Architect application enforces restrictions on verbatim control path definition. For more information, see Verbatim control path restrictions.
- When the RefName path is complete, click Done.
The Coding Dictionary dialog box appears.
- From the Select Coding Dictionary drop-down list, select the dictionary to use for coding the verbatim.
Click OK. The InForm Architect software inserts the path into the component definition you are creating. A new verbatim node appears under the visit, along with empty nodes for the code targets and context items defined for the selected dictionary.
- Edit the verbatim properties in the Properties window. For more information, see Verbatim control mapping properties.
