Verbatim control mapping properties
The following table describes the properties of a verbatim control mapping:
Property |
Description |
Control Path |
RefName path of the verbatim control. READ ONLY. |
Dictionary |
Coding thesaurus used for coding the verbatim. If you change this property, the InForm Architect application updates the dictionary and, as necessary, the code target and context item control mappings. For more information, see Verbatim dictionary updates. REQUIRED.. |
Verbatim Type |
Specific type of verbatim defined in a coding dictionary. The following verbatim types are defined for the dictionaries supported by Central Coding:
OPTIONAL. |
